Process isn't monitored: Process is ready to be monitored, waiting for injection status
(There is no logging, process is a pod in Openshift. /var/log/dynatrace/oneAgent not available)
Who has seen this message and or knows what to do?
KR Henk
Thats a new one for me @henk_stobbe. Were you able to get clarity on this? Did the process need a recycle for the injection to happen?
I got this ā€œerrorā€ too, but on a java process, i would love to know what to do with it.
Can you tell us what entries you have in the OA logs?
Then it will be easier for us to tell what is the cause.
Radek
Hello Akos,
Can you please check the JVM version? (and check the supported by Dynatrace page)
KR Henk
Got it @radek_jasinski , @henk_stobbe , as the log file says: JVM not supported, Deactivating agent.
Thank you for the help
