Why processes are not detected?
One of the following may have occurred
  • The process isn’t supported by our monitoring technology. You can always check which process types Dynatrace supports.
  • The process isn’t working on your server. Make sure your servers are running and that the processes are operational.
  • There is delay in communication between Dynatrace and your OneAgent. If this is the case, wait a few moments and try again.
  • Your OneAgent isn’t working properly. Go to Settings > Monitoring overview to confirm that monitoring is enabled for the host running your software.
  • Try installing OneAgent on a different machine.
Adding to the above the below documentation page explains which are the most important process to be monitored based on the technology, CPU, memory consumption & network traffic.
