Am I correct in assuming that when using a proxy to access a service on the internet, Dynatrace does not see a third-party call but a call to unmonitored host.
And so you can not create a custom device or separate service? )-;
KR Henk
KR Henk
Hi Henk,
It should be possible to create a separate service for calls to unmonitored hosts using the Service detection API. Here is also a blog post with an example.
Sia
Hi Sia,
Sorry can only give you one Kudo, you are right!
UI with custom device does not work, but the API works perfect!
For reference the code so other people can save some time:
“type”: “OPAQUE_AND_EXTERNAL_WEB_REQUEST”,
“name”: “Here the Name”,
“description”: “Some description”,
“enabled”: true,
“conditions”:
{ “attributeType”: “URL_HOST_NAME”,
“compareOperations”:
“type”: “STRING_CONTAINS”,
“ignoreCase”: “false”,
“values”: [“Here the hostname from the URL”]
“applicationId”: {
“valueOverride”: “The new service name”
“port”: {
“doNotUseForServiceId”: “true”
