Pull Tags from Synthetic API
I’ve had a look around the Dynatrace documentation for APIs and it doesn’t seem obvious whether I can pull all synthetics within my environment and their associated tags? I know I can do it for one synthetic but I need it for all.
My use case is that I am going to pull in the data into Power BI and use the tags as filters/slicers.
Any ideas
I would say:
  1. Call Monitored entities API - GET entities list.
  2. Filter Synthetics only.
If general list does not contains tags, you need to call for Monitored entities API - GET an entity each entity.
Best regards
This worked perfectly. Thank you! Have a good weekend.
Thank you and same to you! 😎
