PVC not bound
PVC metrics (used, available, capacity) are visible in our environment, which indicates PVC monitoring is enabled. However, PVC phase information (Bound/Pending/Lost) and the K8S_PERSISTENTVOLUMECLAIM smartscape object are not available. Could you confirm whether additional configuration, RBAC permission, Kubernetes monitoring setting, or feature enablement is required to expose PVC object metadata status fields ?
