Queries per request in Dynatrace
HI all,
I have 2 view, top requests and number of calls to databases.
What I’d like to see is which requests make the most database calls?
Thank you.
Hello @msmith1
Try the following method:
Using Diagnostic tools > To web requests > Service-level backtrace of requests/ or service flow.
Babar
Once you’re at the view Babar mentioned, you’ll want to change the metric you are displaying.
This metric is also available to query through the Metrics v2 API or plot in a dashboard.
Thank you for replying, my apologies for my delayed response.
This is what I had in appmon and this is what I have in dynatrace. The requests outweigh the db calls it’s hard to see an actual trend (and that’s just 7 days worth).
Any suggestions?
thanks
