Running
Get-WmiObject -Query "SELECT * FROM MSFT_NetTCPConnection where localport=443" -namespace "root\StandardCIMV2"
locally gives a list of data that is very big. I have been able to reduce it by grouping:
Get-WmiObject -Query "SELECT * FROM MSFT_NetTCPConnection where localport=443" -namespace "root\StandardCIMV2" | Group-Object LocalPort
Wondering though how can I do it efficiently with the WMI v2 extensions ?
BTW, the idea is to have metrics for the number of established web connections (I’ll probably filter additionally by state…).
You could make the query more manageable by trimming down the query down to just the required properties with something like:
Get-WmiObject -Query "SELECT Name, OwningProcess, LocalPort FROM MSFT_NetTCPConnection where localport=443" -namespace "root\StandardCIMV2"
But unfortunately piping to Group-Object to get a total is not supported by the data source.
Have you looked at the metrics provided by:
Get-WmiObject -query "SELECT ConnectionsActive, ConnectionsEstablished, ConnectionFailures, ConnectionsPassive, ConnectionsReset FROM Win32_PerfFormattedData_Tcpip_TCPv4"
They may not be fine grain enough for what you need though. If they work, they are counter metrics so you need to handle them as such:
metrics:
- key: com.dynatrace.extension.host-observability.network.tcp.connections.active
value: column:ConnectionsActive
type: count
