Querying the metrics API with nullable values and Inf resolution
I’m using flagger for canary deployments, which always makes queries with infinite resolution, in order to resolve the entire query to one number.
I’m trying to make a query that returns the failure rate of a service, based on the outcome dimension of a metric of request length.
My problem is that the metric I’m querying is sometimes null, so I have to use :default(0, always), otherwise:
The metric expression yielded no data points and/or matching dimension tuples for the query timeframe. Consider appending the default transformation (for example, `:default(0)`) to the operands.
But this is incompatible with a resolution of Inf:
Illegal transform operator: Usage of default operator is only supported for resolutions other than `Inf`
I’m not able to change flagger to not use the Inf resolution.
My full query:
    http.server.requests
    :filter(
        and(
            eq("k8s.namespace.name","namespace"),
            eq("k8s.workload.name","deployment name"),
            ne("outcome","SUCCESS")
    :count
    :splitby("k8s.pod.name")
    :default(0, always)
    :filter(
        and(
    :count
So how else could I approach this query to get a rate for http.server.requests failures?
