Questions about alerting DEM Units using Email or Slack
Hi, We need to know if a customer is close to consuming all their DEM Units. Is it possible to set an email or slack alarm to warn about that? Thanks, Baijun.
Yes, you have DDU’s metrics.
And then, you can create your own metric events base on those.
You only need to be matching some alerting profile and problem notification as well.
Best regards
Can I collect the current month’s DEM consumption per minute using Metric Events in Dynatrace? If not, what could be a workaround?
You have “builtin:billing.ddu.metrics.*”.
Best regards
