Questions related to tenant migration and its impact to activegate and agents
We are in process of migrating our tenant from AWS to Azure based Dynatrace SaaS. We are using monaco to migrate all the configurations from old to the new tenant. my question are mentioned below
1. After migration what steps we need to take on the active gate  configuration level and what needs to be changed
2. What changes needs to be done on the one agent level and does it require an oneagent service restart.
FYI all our agents are sending data to active gate and then the active gate sends the data to the SaaS tenant
You have different alternatives. You can check migrate Managed to SaaS documentation. Different stategies to Migrate ActiveGate and Migrate OneAgent.
Best regards
