Remote agent configuration/switch - how to do it when agent is sending data via env. ActiveGate ?
We were trying it today - after Active Gate is connected to new SaaS tenant - the remote change of OneAgent is not possible. Thinking about 2 AGs in parallel → but then we need to open all FW connections to new AG.
Do we have any better option ?
BR, Josef
You can check Migrate ActiveGate options.
Best regards
