Settings that OneAgent connect directly to SaaS tenant when install ActiveGate
Hi all,
We install ActiveGate to monitor VMware vCenter.
In this case, is it possible to do setting that OneAgent connect directly to SaaS tenant not to ActiveGate?
Best regards,
Tomoko Fukuda
There is no such setting at the moment. However, you can firewall the ActiveGate port (9999/tcp) so the agent won’t be able to connect to the gateway.
Anyway - ActiveGate introduces some benefits such as connection compression (up to 75%). I prefer having the agents connected via the ActiveGate unless there is a very good reason not to do so.
Thank you for your information!
I believe setting “MSGrouter” to “false” should help here.
Please see the help page for details: https://www.dynatrace.com/support/help/setup-and-c…
HTH,
dave
Well seems it should. I was not aware of this property.
