Red Hat Ansible for Workflows: Field ExtraVars is ignored by Automation Controller
If extra_vars are sent from the workflow action "Launch job template" and they are ignored on the Automation controller, check the following setting of your job template in the Automation Controller.
Make sure that the checkbox for “Prompt on launch” for variables (extra_vars) is checked on the job template in your controller.
