<span class="">How can that be solved? I need to remove the comma to be able to add all the fields.</span><span class="">The field I have is called totals.
I need to get a report where I can add up all the sales.
583,100
with that format it doesn't let me add, that's why I need to remove the comma</span>
No, it’s not possible to solve it. You need either two capture groups or do a replacement. None of these is available in request attribute cleanup rules.
Depending on the source of your request attribute, it is possible it can be obtained by other means (without the point/comma character). In general, this cannot be solved using the cleaning rules in Dynatrace.
