I was rather surprised to learn that the release monitoring feature of Dynatrace seems to NOT WORK with processes where no code-level module exists.
I have two pods in my K8s playground, one contains a Nginx container and the other one a Python container. Both are configured with the same standard k8s labels for version, which is also propagated ton environment variables of the process in the deployment spec (as described in the documentation)
spec:
replicas: 1
selector:
matchLabels:
app: dt-metricexport
template:
metadata:
labels:
app.kubernetes.io/version: 1.0.0
spec:
containers:
- name: dt-metricexport
image: 360performance/dt-metricexport:latest
imagePullPolicy: Always
env:
- name: PYTHONUNBUFFERED
value: "1"
- name: DT_RELEASE_VERSION
valueFrom:
fieldRef:
fieldPath: metadata.labels['app.kubernetes.io/version']
In Dynatrace we can confirm the pod labels, however for Nginx (code module exists) more details are picked up (environment variables are propagated to tags automatically, release and stage meta info is created):
For python however (no code module), only the pod label is detected:
The Release overview page only shows Nginx:
In my opinion this means the feature is not complete and/or the documentation for it is not correct.
Please correct me if I’m wrong ![]()
According to the documentation you can use either environment variables OR K8s pod labels. Although the example states to also propagate the labels to environment variables.
In reality it seems that only environment variables (or the tags created from it?) are being used, and since environment variables are only evaluated for processes with code modules it fails for e.g. python processes.
Since the documentation states to stick to k8s recommendations for labeling, Dynatrace should also stick to using these labels directly. Otherwise there will be a discrepancy between other K8s management solutions and what can be seen in Dynatrace. That would be a shame and leaves this feature somewhat crippled.
I’d expect to see all processes on the release overview, not only those where Dynatrace is able to detect services due to code module support.
kr,
Reinhard
