Renaming a Process under Process Group
My process name is not listed with same as App Name. For example under
Management Zone → Hosts → Process Analysis among listed processes
We are expection process name as equal to app name (actually app name running in server is with -Dapp.name=FH_MTE_instance1)but the same is not displaying instead it is displaying with “instance1”
So Management Zones wont rename processes. The Management Zone will organize the process. Are you able to provide a screen shot of the processes and show its properties, mainly the detected name? If you want to rename the process, you’ll have to go into the environment settings and select Processes and Containers > Process Group Naming, when you rename the group, you rename the instances in the group.
