REST API for Dynatrace Group Management
Does the Dynatrace SaaS solution have any sort of REST API that can be used to manage groups? I see some questions/RFEs that are pretty old at this point. Curious if anything has been created/provided recently that would facilitate this automation…
Thanks!
I dont believe so that there is an API for the SaaS cluster but you can integrate with AD via SamL.
We’re actually planning to use SAML, so the user to group associates will be covered. What I’m looking for is a way to define the groups within Dynatrace versus having to log in and configure them manually via the web UI…
As it stands now, there is no solution to do it via the API. I dont think it is on their road map either, You can submit the product idea if you’d like and state your use case: https://community.dynatrace.com/t5/forums/postpage/board-id/DynatraceProductIdeas
Thanks for putting in the RFE - I have up voted it :slightly_smiling_face:
Link to the RFE: https://community.dynatrace.com/spaces/483/dynatrace-product-ideas/idea/238196/provide-restapi-for-managing-dynatrace-saas.html
Update 07 Apr 2021 - Status “Completed”; The functionality has been delivered
Thanks for the pointer and information!
you’re welcome! ohh and dont forget to mark it as the best answer :slightly_smiling_face:
