Restoring cluster node
We are planning to implement a Dynatrace Cluster with 3 medium size
nodes, but before we got the hardware for the nodes with the resources required
for medium size, we had to implement the server on a node with lower resources
(about a small node) because we had a critical performance issue in our
application and we needed to find the cause immediately. We want to keep the data and configuration that we have already on the node, so the plan is to make a backup and restore it in a medium size node. So is it possible to restore that node on a medium size node, no mattering that have different hardware resources?
You can always restore a cluster on a bigger instance. Backup is hardware agnostic, however when you restore that on a smaller instance it is possible it won’t be able to handle the same load.
