Good morning community, I need your support. I have the following requirement: I am injecting data via API into Dynatrace, specifically LOGS. In the log content, I have a special field that is different and conditional for different development teams that I have and use Dynatrace. I want this field to be a key, for example, if the field has specific data for team X, they can see it but not team Y, and if it has data relevant to team Y, they can see it but not team X. I have been exploring user policies, segmentation capabilities, and even boundaries. Could you recommend the best approach? Thank you.
I have just not done that by myself, but I would try using Openpiline for adding some security context to your logs records.
And then, create a policy only for that security context. And that policy can be added to group team.
Best regards
