Log monitoring - enable on a user level
I know the log monitoring is applicable on three scopes (Host / Host Group / Tenant).
So is it applicable at Dynatrace to get it enabled on the user level also as per the customer request?
If yes, how could it be enabled?
Thanks.
@Peter_Youssef you can set detection on certain log actions/entries from the users interacting with the entities but I don’t think you can set it to Monitor/capture logs for a specific user leveraging the system. You would need to have monitoring enabled and you can then formulate detection/identification of users via the data supplied in the logs.
