Is it possible to have a longer retention period ** For Audit Log ** instead of the standard 30day on Dynatrace SaaS?
Please take a look at the checklist migration plan.
I don’t think this is the correct answer. here I’m referring to retention for audit log and for Dynatrace Saas ![]()
Right!!!
Regarding Audit logs, the answer is no, but you can create a workflow to query and ingest the logs into Grail.
Hi @y_buccellato !
Dynatrace now provides an application called “Privacy Rights” for storing audit logs in Grail and viewing the results:
You can create a custom log bucket with custom retention ![]()
But this is just for the audit logs for the “Sensitive Data Center” app, not the general Dynatrace audit logs, no?
