Revision History of Monitoring Configurations
Greetings,
Over the years I have used the “Revision History” on metric events to see who has changed what settings and when.
There was a convenient button you could press in the UI that would show you what was changed.
Is there a reason that button doesn’t exist for regular monitoring configurations located in extensions?
I understand that I could use the API, but that isn’t a very smooth flow to getting this data.
Revision history should be more easily accessible within the GUI.
Matt
Upvoting this, with the larger environment and setup. This should be consider as security perspective also. Where these monitoring configuration cant be controlled or restricted with MZ specific or any other filter specific. So the roles and permissions playing zero role here.
As mentioned by Matt, this will ensure the validation of history of changes.
