Revisions for key for schema are outdated
I am trying to update a metric event through the API, just to enable/disable it.
I initially succeeded to PUT the updated payload and got a 200. But after that, every attempt to modify it results in a 409 Conflict error with the following message:
Revisions: '\n ‘<some ID>’ for key ‘<some other ID>’ for ‘<schemaid>’ are outdated.
The only variable thing in my payload seems to be the update token, which I grabbed from the API tab on the metric event I wanted to modify, and this doesn’t seem to change, looks more like a unique identifier and not a nonce.
Has anyone encountered this in the past?
P.S. I face this on Managed, haven’t checked if it’s the same case on SaaS.
George
Hi, @g_kat! Have you managed to find the answer to your question? It would be great if you share it with the Community :slightly_smiling_face:
Hi @GosiaMurawska
I ended up automating the procedure with a Python script that invokes the API twice a day to enable/disable the metrics events and I haven’t faced this issue as long as it’s running(>2 months).
I can only assume that when I did my initial tests I somehow created a corner case condition with my API calls, maybe due to rapid calls on the same schema?.
I never bothered to reproduce it since the script worked.
George
