RUM Manual JavaScript tag (jsTagComplete) fails
I inserted
JavaScript tag (jsTagComplete) in my index.html that was provided/generated in my dynatrace Web application
<scripttype="text/javascript"src=“https://apmproxy.redacted.redacted.com:443/jstag/managed/223cc1d7-7ac5-407e-aee0-f60bf83ff6ec/cb4c4caedc78b415_complete.js"crossorigin="anonymous”></script>My app runs at a different domain (apps.redacted.redacted.com) but same subdomain.The Javascript is fetched fine with 200 (no cors etc error).Then it makes a xhr POSThttps://apps.redacted.redacted.com/rb_223cc1d7-7ac5-407e-aee0-f60bf83ff6ec?type=js3&sn=v_4_srv_10_sn_6F29A189F8B7BCD3E86F10C9C748AF0B_perc_100000_ol_0_mul_1_app-3A96b5507b894cc803_1_app-3Af420fffe20f2cdf6_0&svrid=10&flavor=post&vi=FTKFTCRPVMJUHAQRMITHPLIKEMQJRFSC-0&modifiedSince=1658855885893&rf=https://apps.redacted.redacted.com/a/b/c/my-app/#/dashboard/11112&bp=3&app=cb4c4caedc78b415&crc=4006171111&en=f5pi17op&end=1and fails with 404Because apps.redacted.redacted does not host /rb_223cc1d7-7ac5-407e-aee0-f60bf83ff6ec and whats with the path / ?How to fix this ? What am I doing wrong ?
You need to configure it at Application level. Go to your application > … > Edit > Capturing > Advanced settings and under Specify path where JavaScript tag should send monitoring data: you should put the actual path/fullURL where the beacon should report the data to.
Hope this helps!
Cheers!
