I am trying to use this for ingests logs
resume
export STACK_NAME=dynatrace-aws-s3-log-forwarder
export DYNATRACE_TENANT_UUID=*************
export PARAMETER_NAME="/dynatrace/s3-log-forwarder/$STACK_NAME/$DYNATRACE_TENANT_UUID/api-key"
export HISTCONTROL=ignorespace
export PARAMETER_VALUE=********************
aws ssm put-parameter --name $PARAMETER_NAME --type SecureString --value $PARAMETER_VALUE
aws ecr create-repository --repository-name dynatrace-aws-s3-log-forwarder
export VERSION_TAG=$(curl -s https://{environmentid}.live.dynatrace.com" \
DynatraceEnvironment1ApiKeyParameter=$PARAMETER_NAME \
ContainerImageUri=${REPOSITORY_URI}:${VERSION_TAG}-x86_64 \
--template-file template.yaml --capabilities CAPABILITY_IAM
// until here, everything works fine ( except for some errors that appear duplicate function, low concurrency that were resolved)
//optional
aws cloudformation deploy --stack-name $STACK_NAME --parameter-overrides \
EnableCrossRegionCrossAccountForwarding=true \
//validating
echo $STACK_NAME
echo $PARAMETER_NAME
echo $PARAMETER_VALUE
echo $VERSION_TAG
echo $REPOSITORY_URI
//configuration of forwarder configuration
bucket_name: logsdynatrae
log_forwarding_rules:
- name: log_generic
prefix: ".*"
source: generic
annotations:
environment: dev
aws cloudformation deploy \
--template-file dynatrace-aws-s3-log-forwarder-configuration.yaml \
--stack-name dynatrace-aws-s3-log-forwarder-configuration-$STACK_NAME \
--parameter-overrides DynatraceAwsS3LogForwarderStackName=$STACK_NAME
//eventbridge configuration
aws s3api put-bucket-notification-configuration --bucket logsdynatrae --notification-configuration='{ "EventBridgeConfiguration": {} }'
export BUCKET_NAME=logsdynatrae
--template-file dynatrace-aws-s3-log-forwarder-s3-bucket-configuration.yaml \
--stack-name dynatrace-aws-s3-log-forwarder-s3-bucket-configuration-$BUCKET_NAME \
--parameter-overrides DynatraceAwsS3LogForwarderStackName=$STACK_NAME \
LogsBucketName=$BUCKET_NAME \
and next loading to the s3 a log for testing purposes with the next information
logs3testing_01.txt
[2024-04-11 20:39:43.752 UTC] [aws] [debug] For Logs in s3
this can be done in 15 minutes, but after 6 hours testing deploying, understanding, deploying, updating. understanding, validating, get nothing
i am doing something wrong ?
