Scanned Event in Anomaly Detection - cost question
If I “Fetch event” in an anomaly detection, would this generate costs in the platform based on scanned event in Grail based on each Anomaly Detection execution (check)?
I think fetch dt.system.events is not billiable.
Best regards
The fetch events or fetch bizevents do generate query costs while fetch dt.system.events does not.
Thank you, this is the correct answer that I was expecting.
You solved an ongoing intellectual discussion with one peer :slight_smile:
