I checked with the link you’ve provided. Unfortunately, it does not provide any solution to what is needed. Basically it offer the same solutions which is currently available for Reports and Dashboards for Dynatrace Apps(API endpoints).
The solution I use in my clients is to build the reports automatically through the APIs, and then send them out via whatever channel is being used. Some work, but highly configurable.
Thanks for sharing, I went through workflows docs, it has task scheduling and cron features. I’m not sure but I will definitely will try it practically.
It seems a nice idea. Just to make it clearer, do you use Dynatrace Apps to call the API, customize and sent the message via let’s say MS Teams group chat.
Also could you please share if you know any really example on GitHub maybe?
I do not use Dynatrace Apps, but it could be a solution, as also Workflows. They are called at the moment by scripts/programs/extensions, depending on the customer.
They are highly tailored, so I don’t have them in sharable format.
