I know that to receive monthly or weekly reports you need to subscribe to them and it will work.
Is it possible to somehow schedule monthly or weekly reports to be sent to users that don’t have an account in Dynatrace? To configure that some reports will be sent to email or emails XYZ.
We have a need for this and we don’t want to create accounts for this recipients.
Suggestion to do it with “Share” button in each report that will generate some link that we can share and the link is accessible without Dynatrace account is not an option for us because it involves manual action from us.
From that GET Reply you will want to extract the ID and not the Dashboard ID that you just posted. The ID is the actual report ID, you will need this for the next step, this is part 1 of the process.
4 - You’ll then take that Report ID and paste it into the GET for the report details:
This is part 2 of the 3 part API process, please copy this off or download it.
5 - Then take that copy/download and put it into your tool of choice, Notepad, Notepad++ etc… and you’ll want to add the internal/external Email Addresses of the users. Once compiled, copy the entire payload.
6 - Now do a PUT for the report to update the list of user emails that should be getting the report.
My question was not regarding sending reports from Dashboards it was regarding reports that are created automatically every week or month ( Availabilty reports) and then a user that has Dynatrace account can subscribe to them.
So is it possible to do the similar with these reports.?
To do it with dasboard reports I can do it as you described but to ask before starting to create the dashboards that will show the same infos as in Availability reports
