Searching by Bind Variable
We have a scenario where we want to see for example that an ID that has been inserted into a table and later needs to be deleted from that table.
The ID is seen as a bind variable, and I wanted to know if there’s any way to search by this bind variable to see the different sql executions which used it?
@KVZ,
I imagine you are a Managed customer, as SaaS customers don’t have the option to get bind variables.
There is no current way that I know of to find bind variables by their value.
But I get your point, and I believe it would be a good product idea. You can create one in the Product Ideas: https://community.dynatrace.com/t5/Dynatrace-product-ideas/idb-p/DynatraceProductIdeas
Yes @AntonioSousa  something like auto tag top queries with bind variable for advance filter search.
I believe @KVZ  definitely go ahead converting this to an idea
Dears @AntonioSousa & @KVZ
Is there any update regarding this matter?
Babar Qayyum
@Babar_Qayyum for SaaS this is certainly possible for DPS SaaS instances having traces in grail where you can query spans and filter on attributes, including bind variables.
For Managed, I don’t think this is possible at the moment.
Hello @Julius_Loman
I appreciate your thoughtful feedback. However, due to our managed setup, we are unable to take advantage of it.
Babar Qayyum
In Managed, I’d try to define a request attribute to get the value. However, it might not be easily possible. It depends on how your application code is structured.
