Hello everyone
I am integrating the sending of notifications by mail, and I need to send a tag that comes from aws. This tag has this form (in square Brackets): [AWS]Environment
In Tag configuration it is indicated that it should go like this --> {Tags[key]}
How should this configuration be done? I have tried like this: {Tags[[AWS]Environment]}
But it does not work.
@AntonPineiro is correct, you can use the “[AWS]Environment” tag and use that to create a Dynatrace tag, based on the AWS tag. That will allow you to use it the way you want.
