AWS tags applied to processes
We have few mandatory tags that are applied to our cloud instances and these show up (after CloudWatch integration is established) - however we couldn’t push these tags to the processes. We have to configure a another tag to capture that info and apply it to the process.
Any suggestions is greatly appreciated.
The only way I can think would be to apply the tag to the underlying process on the AWS side.  Unfortunately, I don’t think there is a way to propagate those tags to processes/services on the Dynatrace side.
We are seeing this same thing with lambda functions. we can see the tag being pulled in and showing at the aws account level for that function but if you view the service for that lambda the tag is not there.
Hi Travis,
I suggest you submit an RFE with our product team about this concern, as it doesn’t seem to be possible right now.  You could try setting up automatic tagging rules in Dynatrace for your functions to fill the gap.
