I have the same problem and as far as I know, the only way to have AWS labels propagated in Dynatrace is to create a set of automatic tags equivalent to those in AWS where, based on AWS labels, a new automatic tag is created in Dynatrace for all the related elements including nodes, processes and services.
In my case in AWS I have labels for environment with assigned values and the only way I have found to propagate the values is:
create an automatic tag named Environment
for each element type (host, process, etc.) create a rule filtering by the different Environment values (dev, pre, pro) and assigning the same value as in the AWS label
