Tags for Lambda functions
How can we tag for AWS lambda functions?
Isn’t Lamba functions existing like services in dynatrace? In such case you should be able to create some tagging rules to add them automatically.
Hello Tarun,
Yep, Sebastian is correct. Your lambda functions should show up under services. If you filter the services page by technology:Lambda Functions you should see them.
David Nicholls
I have lambda functions that run as a cron, but they’re not listed in services I guess because of the cron job within AWS that executes them. None of my other services communicate directly with these lambdas. Would still be good to get autotagging available on Lambda functions (the way we can autotag classic load balancers, and RDS databases).
The above solution doesn’t apply for Lambda functions detected via CloudWatch integration, but the RFE in the link posted by @ianc addresses that. I’m keen to see that coming into Dynatrace!
hi Andre - I can’t see the post for the link you shared above.  Can you get me to the right place?
Hi @herrmann_andrew sure, here you go: https://community.dynatrace.com/t5/Dynatrace-product-ideas/RFE-Tag-Lambda-Functions/idi-p/148161 (PS: the person I mentioned, @ian_c changed to @ian_cervantez1, perhaps that’s where the confusion came in? :wink: I referred to his post made on 10 Jul 2019 09:30 PM, which you’ll see in this thread - hope I’m making sense )
how to you take a ENV tag applied to my Lambda service via environment variables and apply it as a auto tag ?
