When I try to separate a gRPC call from the requests detected as “Requests to public network” it’s not working. The support suggested to use the Service Detection Rules, but I tried a couple of different rules and didn’t work either.
Hello, please check if you find the grpc path, e.g., “google.bigtable.v2.Bigtable” in the list of watched services (“publicInternetServices”):
see DebugUI > Cassandra-persisted configuration + Auditing > Part: Services configuration > Load latest JSON > “publicInternetServices” list
Unfortunately this is a Dynatrace diagnostic feature that is not accessible per default. Please contact support for help or raise a request for assistance.
@mmsz I don’t know if you still need help with this topic and from what I’ve seen @elodie_lam RF hasn’t been released yet and we don’t have a scheduled date.
However, I managed to break the service through a custom device by entering the called IP range.
To find the IP I checked some requests and established the range: for example 111.11.11.1 to 111.11.11.10
(the field only accepts 10 IPs).
