Hi All,
We are checking the Anomaly Detection settings under Settings → Anomaly detection → Services in Dynatrace Managed.
Currently, options like:
- Detect service load drops
- Detect service load spikes
are getting applied globally across the environment.
Our requirement is to enable these alert settings only for a specific Management Zone instead of the entire environment.
Could you please confirm:
- Is it possible to configure Service load drop/spike anomaly detection Management Zone wise?
- Is there any workaround using custom anomaly detection, metric events, or alerting profiles?
Any guidance would be appreciated.
Sohel Rashid
