Set activegate URL for Solaris OneAgent
Hello team
while checking the documenation for the Solaris OneAgent I couldnt find any configuration steps on how we can set where the OneAgent should be reporting , to which Active gate, how we cant set network Zone, Hist groups…etc
can you please provide more details on this ?
br
Makrem
You can read Get started with network zones. This is in general, no matter which SO you are using.
Best regards
Thank you, but I dont this will help
my main concern is how to configure the Solaris one Agent to point to the specific ActiveGate, as connectivity to the Dynatrace Cluster is not available
  1. Create a network zone.
  2. Assign one or more ActiveGates to network zone.
  3. Configure OneAgent to network zone.
It would try to send information to ActiveGate in same network zone. Of course, you need communication opened from OneAgent to ActiveGate.
You have different examples in documentation.
Best regards
Solaris OneAgent doesn’t provide the same level of installation options as Linux/Windows (it’s a ZIP/preload deployment), so there’s no simple parameter like “point to this ActiveGate”.
To route traffic via ActiveGate, you need to use network zones.
You need to do exactly what @AntonPineiro  described:
Create a network zone --> Assign one or more ActiveGates to the network zone --> Configure OneAgent to the network zone.
When OneAgent is in the same network zone, it will automatically select the appropriate ActiveGate.
The key is to ensure connectivity from Solaris → ActiveGate.
