Hey guys,
I am creating a new SLO using the dynatrace feature. Before that, I have created and testing my metrics on dynatrace data explorer
So I have something like that:
builtin:service.requestCount.total:filter(in("dt.entity.service",entitySelector("type(service),tag(~"CONTAINER:my-container-name~")")))
This brings to me a total of requests as you can see
But I need to get the total amount in a different resolution, instead of 1 minute. I need to a 5 minutes resolution. In the data explorer, there is a resolution field on Settings that I can change it easily
Its works!
But now I need to use this in my SLO. For example:
((builtin:service.requestCount.total:filter(in("dt.entity.service",entitySelector("type(service),tag(~"CONTAINER:my-container-name~")"))):partition("latency",value("good",gt(1000))):splitBy():count:default(0)) / (1 *100))
Everything is ok. I mean the results of this query is ok. But the problem is that the SLO resolution is 1 minute and this affects the SLO result. Is it possible to change the SLO resolution to other value than 1 ?
PS.: I already know that dynatrace works with auto resolution according to the time range that is selected. But in this scenario is not useful for me. I would like to set my own SLO resolution
