So, for many Schema’s you need to provide a token, password, or some form of credential. Here is just one example but their are many. This is for Problem Notification schema.
“url”: “https://*****/api/560751/dynatrace/HM_Dynatrace_Create_Incident”, “acceptAnyCertificate”: true, “notifyEventMergesEnabled”: true, “notifyClosedProblems”: true, “headers”: [ { “name”: “Authorization”, “secret”: true, “secretValue”: “***169***” } ],
You can see there is a ‘secretValue’ attribute. Dynatrace now auto fills with “****XXX****” when you do a get on /settings/objects api. But when i go to do a PUT on /settings/objects/{objectID} there are certain required JSON components that must be provided.
Many times, those JSON objects contain the credential sections. I don’t want or may not know the secretValue or credential but I need to call the API to DISABLE the configuration or change a different attribute. If I make the PUT call without this data, Dynatrace then clears my credential data.
So, my question is how can I do a PUT for an object without having to provide the secretValue but also not clearing out the secretValue.
Thank you in advance.
