Unable to use put method from python for environment API
I am unable to use put method in dynatrace from python requests module, My code is as follows, i am trying to update the credential vault entry it throws the below error,
{‘error’: {‘code’: 400, ‘message’: ‘Syntax error near line 1 column 6’}}
Seems like there is an issue with “:”
<span>def </span><span>put_authtoken_in_dt</span>(vault_id, session_token, name, description):<br>    url = <span>"https://<host>/e/<env-id>/api/v2/credentials/"</span>+ vault_id<br>    <span>print</span>(url)<br>    headers = {<br>        <span>"accept"</span>: <span>"application/json; charset=utf-8"</span>,<br>        <span>"Content-Type"</span>: <span>"application/json; charset=utf-8"</span>,<br>        <span>"Authorization"</span>: <span>"Api-Token <token>"<br></span>    }<br>    data =  {<span>"name"</span>: name,<br>             <span>"id"</span>:vault_id,<br>             <span>"description"</span>:description,<br>             <span>"ownerAccessOnly"</span>:<span>"false"</span>,<br>             <span>"type"</span>:<span>"TOKEN"</span>,<br>             <span>"token"</span>:session_token<br>             }<br><br>    <span>try</span>:<br>        response = requests.put(url, <span>headers</span>=headers, <span>data</span>=data ,<span>verify</span>=<span>False</span>)<br>        <span>print</span>(response.request.body)<br>        <span>if </span>response.status_code < <span>400</span>:<br>            <span>print</span>(response.json())<br>            <span>return True<br></span><span>        else</span>:<br>            <span>print</span>(response.json())<br>            <span>return False<br></span><span>    except </span><span>Exception </span><span>as </span>e:<br>        <span>print</span>(e)<br>        <span>return False</span>
Please let me if i am doing something wrong in request headers.
Hi!
Why you put in authorization
<span>"Api-Token <token>"</span>
token in <> brackets. I don’t know if this is a case but maybe try:
DT_API_TOKEN=“”
“Authorization”: "Api-Token " + DT_API_TOKEN
Have a nice day!
IMHO the error suggests it’s a payload issue, rather than authorization issue.
If I were you, I’d try with the other method to create a payload object. For example:
Spoiler
data = { <span class="hljs-string">"name"</span><span>: name</span><span>, <br></span><span>"id"</span>:vault_id,<span> <br></span><span>"description"</span>:description,<br><span>"ownerAccessOnly"</span>:<span>"false"</span>,<br><span>"type"</span>:<span>"TOKEN"</span>,<br><span>"token"</span>:session_token<br>}
Then convert the payload to JSON format
Spoilerjson_payload = json.dumps(payload)
And then send the PUT request with the JSON payload
Spoilerresponse = requests.put(url, data=json_payload, headers=headers)
