SLO - Best Practise
Hi Team,
I have a question for you guys if you could share your experience in using SLO for environmental reporting for your clients? I have an issue right now to best measure the entire very large environment and I would like to do it as well as possible.
I would appreciate your valuable comments:)
Radek
Hi @radek_jasinski,
as SLO comes along with SRE, the best is using “Four Golden Signals” as a base.
Google SRE: SRE Responsibilities and Management Frameworks shows full explanation with examples.
Then You can obviously go with additional business specific ones as You gather them.
Bests
Michal
Hey @MichalOlszewski,
Long time no see 😉
Thank you for the materials you shared, they will certainly be valuable to me. Have you come across the option that you can set working hours in our SLO? I haven’t found a clear answer. (I assume I can handle this with Maintenance Window, but there is no such option in the direct SLO configuration).
Radek
Hi @radek_jasinski,
Michael Cabrera from Vivint and Andreas Grabner conducted a great break-out session and practitioners guide about “SLOs done right” at PERFORM 2023 (Perform 2023 on-demand | Dynatrace Perform) and as blog Service level objectives done right. Might also be of interest.
Best,
Gerhard
Thank you:)
You should take a look at - GitHub - dynatrace-ace-services/slo-simply-smarter: Best practices - Simply Smarter dashboards (Classic) · GitHub
Get that setup on your environment and see how you feel and think about what JLL has done here. - I use this at my client as a starting point and it’s really nice to show people the ‘Art of the Possible’
This SLO Simply Smarter also uses best practice’s from Google - is has some links.
Maintenance Windows only work for an SLO, where the metric uses them I.E: builtin:synthetic.browser.availability.location.totalWoMaintenanceWindow
https://community.dynatrace.com/t5/Dynatrace-product-ideas/Calculate-SLOs-in-working-period/idi-p/208224
Also Dynatrace will be fixing this, see here: https://community.dynatrace.com/t5/Dynatrace-product-ideas/RFE-Support-for-Business-Hours-in-timeframe-selector/idi-p/154613
@Tom_Eaton Super! I managed to get the desired effect thanks to your advice:)
Awesome :slightly_smiling_face: - Glad it was useful.
