Hey,
The snmp Trap extension does not make it easy to know, which log/custom device is created by which extension config. On the custom devices created, the only attribute present is the dt.ip_addresses.
I have multiple applications sending snmp traps, each having their own support team.
So I have to create auto tag rules for each device sending traps, based on IP.
Example: type(snmptraps:com_dynatrace_ext_snmp-traps),dt.ip_addresses(99.4.50.24)
Repeat 100x ![]()
So it would help if I could add a variable in the extension config “application-name” thats then added to the log entry and custom device.
Is it possible to add vars to log attributes?
And how to achieve this for the snmp trap extension, as only the metric is defined here?
I was thinking about something like this, but it does not work as the custom devices only take their properties from the log records (& metrics) its seems.
My non working custom extension, to give some more context.
version: 0.0.3
minDynatraceVersion: 1.280.0
author:
metrics:
- key: com.dynatrace.extension.snmp-traps-generic.traps.count
metadata:
displayName: Traps count
description: Number of traps received.
unit: Count
snmptraps:
- group: generic
featureSet: Events
interval:
minutes: 1
metrics:
type: count,delta
value: calculated
dimensions:
- key: host_ip
value: const:sender
- key: trap_oid
value: const:trapOID
- key: application_name
value: var:application-name
vars:
- id: application-name
displayName: Application name
description: "The name of the application integrated through snmp traps"
type: text
topology:
relationships:
- fromType: custom:com_dynatrace_ext_snmp-traps
typeOfRelation: SAME_AS
toType: network:device
enabled: true
sources:
- sourceType: Entities
mappingRules:
- sourceProperty: dt.ip_addresses
sourceTransformation: To lower case
destinationProperty: dt.ip_addresses
destinationTransformation: To lower case
types:
- name: custom:com_dynatrace_ext_snmp-traps
displayName: SNMP Traps Device
enabled: true
rules:
- idPattern: snmp_traps_device_{application_name}_{host_ip}
instanceNamePattern: SNMP Traps source {application_name} {host_ip}
sources:
- sourceType: Metrics
condition: $prefix(com.dynatrace.extension.snmp-traps-generic.traps.count)
attributes:
- pattern: '{device.address}'
key: dt.ip_addresses
displayName: Device Address
- pattern: '{host_ip}'
key: host_ip
displayName: IP Address
- pattern: var:application-name
requiredDimensions: []
sources:
- sourceType: Logs
attributes:
key: host_ip
requiredDimensions:
- key: log.source
valuePattern: '$eq(snmptraps)'
screens:
- entityType: custom:com_dynatrace_ext_snmp-traps
detailsSettings:
layout:
autoGenerate: false
cards:
- type: INJECTIONS
- key: traps_charts
type: CHART_GROUP
- key: traps_logs
type: LOGS
width: FULL_SIZE
staticContent:
breadcrumbs:
- displayName: SNMP Traps sources
type: ENTITY_LIST_REF
showAddTag: true
showGlobalFilter: false
showProblems: true
showProperties: true
showTags: true
chartsCards:
- key: traps_charts
displayName: Trap statistics
numberOfVisibleCharts: 2
mode: NORMAL
charts:
- displayName: Traps Count
graphChartConfig:
metrics:
- metricSelector: com.dynatrace.extension.snmp-traps-generic.traps.count:splitBy()
visualization:
seriesType: COLUMN
visualizationType: GRAPH_CHART
- displayName: Trap OIDs
graphChartConfig:
metrics:
- metricSelector: com.dynatrace.extension.snmp-traps-generic.traps.count:splitBy("trapoid")
visualization:
seriesType: COLUMN
stacked: true
logsCards:
- key: traps_logs
displayName: Trap details
filterQuery: dt.source_entity inEntitySelector "$(entityConditions)"
pageSize: 10
showFiltering: true
enablePaging: true
