SNMP trap processing
hello,
I received a trap like this:
“event.type”: “LOG”,
“content”: “SNMP trap (SNMPv2-SMI::experimental.94.0.4) reported from src:10.10.10.12\n agent:10.10.10.12”,
“status”: “NONE”,
“timestamp”: “1775468179963”,
“loglevel”: “NONE”,
“log.source”: “snmptraps”,
“dt.openpipeline.source”: “extension:com.dynatrace.extension.snmp-traps-generic”,
“snmp.trap_oid”: “SNMPv2-SMI::experimental.94.0.4”,
“device.address”: “10.10.10.10”,
“dt.entity.snmptraps:com_dynatrace_ext_snmp-traps”: “CUSTOM_DEVICE-BLABLA”,
“SNMPv2-MIB::snmpTrapOID”: “.1.3.6.1.3.94.0.4”,
“DISMAN-EVENT-MIB::sysUpTimeInstance”: “1033947497”,
“SNMPv2-SMI::experimental.94.1.11.1.7.16.0.136.148.113.161.162.91.0.0.0.0.0.0.0.0.0”: “2”,
“device.name”: “huhu.eps.com”,
“node.fqdn”: “huhu.eps.com”,
“snmp.version”: “3”,
“SNMPv2-SMI::experimental.94.1.11.1.8.16.0.136.148.113.161.162.91.0.0.0.0.0.0.0.0.0”: “.0.0”,
“SNMPv2-SMI::experimental.94.1.11.1.9.16.0.136.148.113.161.162.91.0.0.0.0.0.0.0.0.0”: “MAPS-1010 Port(s) fenced due to RuleName=defALL_OTHER_F_PORTSITW_40, Condition=ALL_OTHER_F_PORTS(ITW/min>40), Obj:port5, F-Port 5 [ ITW,43 ITWs].”
I would process this trap and create a problem if the word “fenced” appears anywhere.
My issue is that “fenced” is located in the field
where SNMPv2-SMI::experimental.94.1.11.1 is static and the rest is dynamic, it looks like a device identifier.
How can I filter the value “fenced” in this field for all incoming messages on all devices?
@MichalSzekely ,
Traditionally you’ll have to configure a “Log custom attribute” to search it. In Grail, never did SNMP traps myself, I would have to ask someone that did.
Did you manually change the last part to 0.0.0.0.etc ? Usually there is a still a field-identifyer and after that might be some dynamics. In the snmp-trap extension config you can define that it should trim some last digits from the oid, to only have the devicetype+fieldnumber which you can use to capture the exact field you need. This is always a hard thing to handle, but at least some description on this can be found here:
In openpipeline-logs (filter: log.source==“snmptraps”) you can then create nice attributes, and based on those attributes you can trigger an event in the openpipeline.
In SNMP trap extension, edit monitoring configuration for the related devices, in the list of endpoints expand the corresponding endpoint, scroll to to bottom and click Add  varbinding, set these values:
OID Prefix: SNMPv2-SMI::experimental.94.1.11.1
Number of octets trimmed: 17
