Splitting of Java Process Instances
Hi all,
I am facing a problem with Dynatrace configuration when monitoring a Java process that starts multiple instances. The only difference between these instances in the command line arguments is the -DAppName parameter, for example:
-DAppName=Process1
-DAppName=Process2
Currently, Dynatrace is grouping all these instances within the same process group. I would like to separate them so that I can correctly set the memory parameters for each instance individually.
I have tried looking for solutions in the documentation, but have not found a clear way to perform this separation. Has anyone faced a similar problem or have any suggestions on how I can configure Dynatrace to recognize and separate these instances into different process groups?
I appreciate any advice or guidance you can offer.
Thanks in advance!
I would suggest you creating a detection process group rule. You can adapt your logic for different conditions.
Keep in mind process should be restarted to apply rule.
Best regards
