What are the required steps to install OneAgent on 100+ servers using SCC?
Suggestion to check these:
Deployment API: Deployment API - Orchestration tarballs — Dynatrace Docs
Hi @kmanoharan24, did you find Danne’s comment helpful? Hopefully, you were able to find your answer behind those links :slightly_smiling_face:
