Synthetic Engine status​ Shutting down after upgrarde to 303 on Windows
Hi guys,
Windows AG was upgrade from version 301 to 303 and momentarily after that Synthetic Engine status changed to ​Shutting down.
We have tried to restart the services and the whole box same behavior, i.e.  Synthetic Engine status changed to ​Shutting down after few minutes.
Did anyone experienced  same behavior ?
Thanks for any input
Yos
Hi Yos, thanks for letting us know. Can you check the vuc-status.log for which module is not starting? You can then check the relevant module logs.
https://community.dynatrace.com/t5/Troubleshooting/Why-is-my-Synthetic-ActiveGate-shutting-down/ta-p/239408
