Hello, I’m using the extension Synthetic SFTP monitor (2.4.0) to detect if a file is not processed by a client (older than 10mn). Apparently this is not working for me.
I rode the code of the extension and saw (if I’m not mistaken) that the file age is tested only if the file suffix is provided :
if (configuration.test.process_file_suffix
and configuration.test.process_file_age
and process_file.filename == str(configuration.upload.local_path.replace('\\', '/').split('/')[-1] + configuration.test.process_file_suffix)):
self.logger.debug(f"{process_file.filename} ends in `{configuration.test.process_file_suffix}`.")
within_limit = self.is_file_within_age_limit(process_file, processing_time, configuration.test.process_file_age)
In my case, there is no suffix when the file is handled by the consumer. I think that’s why the detection is not working for me. Is it necessary to leave this condition ?
BR,
JP
