yes this is possible. Itâs not too straight forward though. You can use the relationships in entitySelectors to identify those services. See my Pro Tip post here. Number 7 in that list is doing it the other way around (tag applications up from services, but if you use a âtoRelationshipâ from the Application entitytype you should be able to achieve this.
You can use this selector in an auto tagging rule which would then also assign the same tag (tagOfApplication) to the services. And then further on use this tag in you MZ assignment rule.
Only drawback: you cannot use placeholders or key:value tags for entitySelector rulesâŚ
Get lost a bit on what are the allowed types for toRelationships.calls so my question is if there is a way to tag all services in service flow that are being called from a specific Key User Action?
