Terminated Host
OneAgent Deployment Page (Environment >> Manage >> Deployment Status)
Under the dropdown menu. Show host that were active in last month or earlier.
It will shows hosts that were terminated. Is there any way to clean it or removed it?
There is no way to remove them, they will disappear after a while.
I think they disappear completely after 365 days.
If I understand you correctly,
It means such settings exist but its not open to the users.
No, it’s just that entities stop appearing after a certain time.
However, if you still have the corresponding EntityID, you will still be able to find them from the previous time period.
