When using Terraform Dynatrace modules namely dynatrace_mangement_zones_v2 and metric_events I have notice that changes made to configs created in Dynatrace would generate a new config setting instead of updating the original. Dynatrace will show two of the same config, the original and the one with changes and config1.tf
Am I making a mistake when exporting the module?
I’ve tried -export and -export -import-state, both duplicates
I make changes to the configs brought over from the UI and run a terraform plan
The plans always state an add rather than a change.
I have once run an apply just to see if it would update anyway and in the UI it will show the original file plus original1 file with the updated config
I just wanted to know if there’s a flag I’m missing during the export to ensure it changes files rather than sees it as an add
