I’m working on implementing a Terraform configuration for Dynatrace across multiple environments (e.g., prod, test). I have no issues exporting the existing configuration or importing state, but I’m looking for advice on how to best organize the exported data.
By default, the export creates a structure with a configuration folder with modules. Is this the recommended approach, or is there a better way to structure it—especially when managing multiple environments?
Since I’m new to this, I’d appreciate any guidance on how to visualize and structure the project effectively. Here’s what my directory looks like after a partial export:
I created a terraform structure, where I use separate terraform-workspaces to keep the state of the individual tenants (Dev/Test/Acc/Prod), and created settings.yaml file per environment:
terraform
environments
develop
settings.yaml
test
settings.yaml
acceptance
settings.yaml
production
settings.yaml
In the locals.tf, I read the correct settings file per tenant, based on the workspace name… So if I “terraform workspace select develop”, automatically my /environments/develop/settings.yaml gets activated.
In this way I can easily create specific variables containing configuration items/names specific to an environment (e.g. HOST-GROUP-12345678) or specific name-prefixes which are different between environments (e.g. subdirectory names in log directories).
Further I created multiple “top-level” main-entries, like “system” and “sre” to make a splitting between resonsibilities. Inside those directories I’m keeping the original module names as visible in the export, because that gives me a hint of the original API/rule that is used to inject the setting…
Thank you @SjoerdB - I’d be very curious to learn more about how you’ve built this out with Terraform workspaces. It seems like a slick way to have support for a common configuration of resources across mutiple, separate Dynatrace tenants each with unique id’s for the same configurations (e.g. scoped by host group, host id, service id, etc) Do you have a repo somewhere or more detailed examples to share?
